How to install CK71 DRLs
Tools required:
Flat head screw driver
Phillips screw driver
Plastic trim removal tool (to remove plastic clips)
Long needle nose plier
With the front bumper removed. Place it facing down, so that you will be able to remove the side air ducts. NOTE: Place some towels or rags under the face of the bumper in order to protect the paint from getting scratched
1. Once you have identified the side air ducts, using your plastic trim removal tool or flat screw driver, proceed to remove the 2 plastic clips that attach the duct to the bumper.
2. With the plastic clips removed, using your Philips screw driver, undo the 3 screws that attach the duct to the side vent.
3. Repeat steps 1 and 2 on the other side of the bumper.
4. Once both ducts are removed proceed to remove the vent both sides of the bumper, by pulling up.
5. With both vents removed, proceed to install the CK71 DRL vents on the same location as your factory ones. You will need to push down with medium force. You should hear and feel the vent clipping on to the tabs once it’s fully sited
NOTE: In order to make sure you are installing the vent on the correct side, make sure the cable coming from the back of the DRL is facing up. Make sure the tabs line up.
6. Once both vents have been installed, proceed to install the air duct back on each side of the bumper. Start by lining up the top part of the duct (where the plastic clips go) and then line up the bottom part, paying attention not to damage/crush the cable coming from the top of the vent.
NOTE: Make sure that the cable is positioned outside of the air duct and that it is not getting crushed by it.
7. With everything lined up, proceed to install the clips and screws back on both sides of the bumper.
8. Now that the CK71 DRLs are mounted to the front bumper, proceed to the driver installation on the car.
9. Run the cables with the T-tap connectors through the opening shown on the photo below. This will route the right behind the headlight harness. Repeat the same process on the other side of the car.
10. Identify the cables on the factory headlight harness that will need to be tapped into in order for the CK71 DRLs to function properly.
NOTE: Use the needle nose plier in order to crimp down the T-tap connector on to the factory harness.
Driver side---------------------DRL
Grey/Yellow-------------------Black
Yellow--------------------------Amber
Grey----------------------------Red
Passenger Side----------------DRL
Red--------------------------------Red
Orange---------------------------Amber
Black/Orange------------------ Black
11. Once all cable connections are done, secure the drive box with cable ties to the wiring loom closest to it.
12. With everything in place, proceed to reinstall the bumper, by plugging in the CK71 DRLs first (Make sure you test connectivity and all functions before mounting the bumper completely)
CONGRATULATIONS!!! You have completed the installations of your CK71 DRL’s. Enjoy!!
Thanks man. Its been a long time coming.
Make sure you check out the official release post to place your order.
2018 Snow White KIA Stinger GT2 RWD
Thanks to both RobZ and Chris71. Awesome product and tremendous price. Would it help y'all to reach out to K8STINGERSTORE.COM and KHARtunerz.com to see if they might purchase them in bulk after you fulfill forum request? That way you can get them out there and make some dough after y'all put in the r&d time as well production cost.
Charlotte
I can tell you our lights will be at SEMA;) beyond that you will just have to wait and see, ha!
Thread Starter #7
Ha!....beat me to it @Chris71
Sent from my SM-G960U using Tapatalk
Charlotte
I should say our lights lol, you worked very hard to help me with the design Rob;) thank you!
Thread Starter #9
Fixed [emoji6]
mountain lakes
2020 Sringer GT AWD
Thanks a lot for sharing this. I'm waiting to get my CK71 lights to install myself.
I have the 2020 Stinger GT, do you know if it will have the same wiring and colors that you have outlined in you post? I think I read somewhere that the different stinger models may have different wiring set ups.
Sent from my SM-N986U1 using Tapatalk
johnls2
Mason
2019 Stinger GT2
#11
Great write up and pics. Does anyone know where you can get the wiring harness that plugs into the headlight socket instead of tapping into the factory wiring? CK71stinger is no more.
