Kia Stinger Starting Engine with weak Battery
South Korea
Kia Stinger
If the battery is weak or the smart key does work correctly on the Kia Stinger, you can start the engine by pressing the engine start/stop button with the smart key.
The side with the lock button should contact the engine start/stop button directly.
When you press the engine start / stop button directly with the smart key, the smart key should contact the button at a right angle.
When the stop lamp fuse is blown, you can't start the engine normally. Replace the fuse with a new one. If it is not possible, you can start the engine by pressing the engine start/stop button for 10 seconds while it is in the ACC position. The engine can start without depressing the brake pedal. But for your safety always depress the brake pedal before starting the engine.
Do not press the Engine Start / Stop button for more than 10 seconds except when the stop lamp fuse is blown.
