Rear hatch this noise
Roseville
MI
2021 Stinger GT
Seen several threads asking about this and not to many clear answers besides the TSB and people using tape. Remove the two upper rubber pieces and install a 5/16 zinc plated washer to each hole on the back side of the mount. Noise will no longer exist.
mountain lakes
2020 Sringer GT AWD
Would you mind sharing a picture of the specific area you're referring to. Thanks
Sent from my SM-N986U1 using Tapatalk
mountain lakes
2020 Sringer GT AWD
It works! I went to Home Depot and bought washers installed them. Then I drove my usual spot with pot hole patches and bumps. Not one rattle. Thank you
A couple of notes from my experience
1) Only the 5/16 washer worked. I bought the 1/4 but the bolt goes not go through the hole. The 5/16 washer was the exact size as the ring on the bumper thing.
2) Other observation is the the bumper guard no longer sits flush onto the trunk lid (see pic). I have some foam padding at will trim it to the size of the bumper guard and put that in between. I may try to use the foam without the washer, as I'm guessing that the bumper guard is what is rattling against the trunk. I'll keep you all updated.
S
Roseville
MI
2021 Stinger GT
Thread Starter #6
Yea I was thinking about just putting some all weather padding there instead. I would hate for it to rust there or break. It didn’t feel like the trunk was any more snug. I suggest 1/8 in thick foam. I’ll try it this week and post if it works.
