How To Convert Reverse lights to LED
Thread Starter #21
you need to remove the bar in order the take bulbs out. The is no space to maneuver the plug and bulb out of the housing with the bar installed.
Charlotte
#22
Or u can pop off the plastic cover, plenty of room if you remove it
Surprise
2019 Stinger
#23
Thank you so much for this write up. It helped me IMMENSELY with installing my T15 bulbs over the weekend.
I do have one tip for other members wanting to do the same thing.
Once the connectors have been unplugged, you can now proceed with the removal of the light bar.
To do so you will to get you plastic panel remover too and insert it on to the side of the light bar.
You don't have to do this. There is no reason to pry the light bar from the outside. Once you have removed the nuts and connections, gently push on the studs (where you removed the nuts) on either side of the bar and it will pop loose. (y)
