Kia Stinger Aftermarket Wheel Options
+35mm is 5mm too high and will stick out for a 10, I'd wager a +40mm will sit just right.
@robz32 Is correct, you would need a 40 to 42mm offset, If you go 10.5 wheel you would need a 45mm offset so the wheel doesn't stick out.
Dallas
2018 Stinger GT2
Went through Getyourwheels.com for these rims, and the sales rep, Jason Tung, was great and everything went smoothly and they were delivered in a timely manner.
The wheels are Stance SF07 Dual brushed gunmetal, 19x8.5 all around, with +35 mm offset, with Pirelli P Zero.
I tell you what, new rims really enhance the character of the car.
great choice, looks good(y)
HEVY.GT
Atwater
2022 KIA STINGER GT2
hey guys, got the car dropped on ARK springs and added Vossen HF3 wheels. 19X8.5 front, 19 x 9.5 rear. using oem tires for now, but could go up a size when it's time to replace them. worked with Diego and Jereme at Vossen and bought direct from them. I worked with Diego in the past on a previous car. great guys down there. I lost about 5lbs per wheel on the front and 7 lbs per wheel in the back versus the stock wheel weights. I simply weighed each weel on my home scale so not super scientific but you get the idea. they are far lighter. Wheels are transparent gloss black finish. They fit pretty flush with fender as well. Pics: View attachment 3940 View attachment 3941 View attachment 3942 View attachment 3943 View attachment 3944 View attachment 3945 View attachment 3940 View attachment 3940 View attachment 3941 View attachment 3942 View attachment 3943
What’s the complete wheel specs if you remember ? I just got a GT2,
19 x 8.5 Front (OFFSET ?)
19 x 9.5 Rear (OFFSET ?)
Welcome @HEVY.GT I know the front is 35 offset & the rear would be around 40 offset
egeck
Denver
2019 Stinger GT2
Niche 19x8.5 Targa M129's in Gunmetal...stock tire sizes 225/40/19's front and 255/35/19's rear...TPMS was tight so had to use smaller ones but works fine...
Draper
UT
2019 Kia Stinger GT1 AWD
Keep getting spammed by Subi sites advertising in stock 18 x 9.5 +38 JDM wheels.
Anyone run something this size on an AWD GT? I'm more worried about the front than the rears.
Welcome, You can use a 18 but you have to make sure the offset is spot on so the wheel will clear the caliper..
Draper
UT
I'm aware you can use 18's. My stock wheels are 18's. I'm asking specifically about the 9.5 +38 itself. Spokes shouldn't be an issue, almost all the wheels are built specifically for large brake kits, like the STI.
Draper
UT
Looks great!
Did you happen to try fitting your rear wheels on the front by chance? I'm curious if those would fit.
u1bud
FLOYDS KNOBS
IN
2022 gt2
Thanks.. I did and they were a little too much poke for my taste.
jamorgan4
San Francisco
2019 Kia Stinger
19x8.5 38 offset tsw Sebring 19x9.5 38 offset factory tires
Black wheels really go well with this car. The pattern on it reminds me of some rims that I see in shops like 4wheelonline. What will be your next plan after replacing your OEM wheels?
Benton
AR
2020 GT1 RWD
Man… making me wanna pull the trigger… then I remember the wife would pull a real trigger if I mess up the “budget” right now… damn party pooper!
GRNWNVY
Highlands Ranch
2022 Ascot Green Stinger GT1 AWD
Hello all,
I have a quick question that perhaps one of the wheel and tire gurus on here can answer.
Why is it that most people who are running a staggered fitment with a 20x9 and 20x10.5 setup are using a 255/35 in the front and a 285/30 in the rear? Wouldn't it make more sense to run a 295/30 in the rear to keep the overall diameter of the tire the same, especially on an AWD car?
Thanks in advance
